15 years agoBCD counter vhdl code
I am a newbie quartus user.. please help me thanks http://i54.tinypic.com/2zp2p3p.png This is my written code: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; e...
15 years ago --- Quote Start ---
library ieee;
entity d4 is
port (reset, sensor, load :in std_logic;
p :in std_logic_vector (5 downto 0);
led_on :out std_logic;
q :out std_logic_vector (5 downto 0));
end d4;
architecture flow of d4 is
signal count_sig : unsigned (5 downto 0);
signal load_sig : unsigned (5 downto 0);
begin
process (sensor, reset, load, p)
begin
if (reset = '1') then
count_sig <= "000000";
elsif rising_edge (sensor) then
if (count_sig = 32) then
LED_ON <= '1';
else
LED_ON <= '0';
count_sig <= count_sig + 1;
if (load = '0') then
count_sig <= p;
end if;
end if;
end if;
end process;
q <= std_logic_vector (count_sig);
end flow;Try this. --- Quote End --- Error (10476): VHDL error at d4.vhdl(27): type of identifier "p" does not agree with its usage as UNSIGNED type thanks for assisting, it's not only the LED that i don't know about .. i feel that my code is not written properly and i can't find out the reason because i was not taught properly.. this one is way beyond my level
