13 years agoBasic MAX V Quartus question
Using Max V and
Quartus II 64-Bit Versions 12.1 Build 243 01/31/2013 SP 1.33 SJ Web Edition First question, what is expected before the primitive? The code below gives this errow message Error (10500): VHDL syntax error at mux_4_13.v(3) near text "primitive"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration" primitive mux (led0,pb0,pb1); input pb0,pb1; output led0; table 1 , 1 : 0 1 , 0 : 1 0 , 1 : 1 endtable endprimitive Second question. Using the Web Edition the options in setting are as follows, VHDL Version 1987,1993,2008 Verilog Versions 1995, 2001, System Verilog. Which do I use or does it make a difference? Thanks Martin2 Replies
Thanks for the help. I was very confused!
Yes, it does.
You're writing Verilog, but Quartus thinks the file is VHDL.
