12 years agoBaremetal examples which uses u-boot doesnt work
Hello I am trying to run Baremetal appication on Cyclone V SoC on SoCrates 1.2 board. Simple applications like Altera-SoCFPGA-HelloWorld-Baremetal works, but as I get to Altera-SocFPGA-Hardware...
11 years agoHi,
Thanks for your reply. After trying out multiple examples I realized that the examples are designed for Altera version of cyclone V and is not compatible with Arrow SoCkit. Even the preloaders that was generated by the hardware I designed doesn't work. Hopefully this is my last question. I found an example from rocket boards which worked. Hence I tried to replace the executable in the example by my application and loaded the FPGA with the hardware I had built instead of the example program. It seems to work. I believe preloader functions are almost common. Is running my application with example program's environment legit? Thanks and Regards, Nitin.
