14 years agobanks and gpio and ports
I noticed that the Cyclone III has banks and the pins are labeled IO and list other functions.....
Are the gpio pins assignable or assigned to a port like a 8 bit or 16 bit port ? I am used to programming pic microchip where each GPIO pin is assigned to a port (ex LATA, PORTD, PORTA) Are all the gpio pins independently assignable to my own specified port or are they split into 8+ bit ports on each bank ? Thanks4 Replies
You find such information in the device datasheet, although this will be an upper limit.
The maximum switching frequency is actually limited by some design specific aspects; for example the selected i/o standard and slew rate strength, external capacitive loading. - Altera_Forum
what is the top speed attainable by an assigned pin if the code was strobing it?
the I/Os are essentially independent. there are exceptions when doing wide, high speed buses like RAM interfaces and LVDS buses
Sure. Any pio pin is freely assignable to any general purpose I/O pin.
You are neither required to route all N signals of a N-bit pio port to the same i/o bank
