14 years agoAvoid Error 10454 - Integer in RANGE
Hello all together, I am looking for a solution to avoid the Error 10454. I know, that this RANGE is not VHDL-conform. FUNCTION summe(
zahl1 : STD_LOGIC_VECTOR;
zahl...
14 years agoHow big is zahl1?
You should initialize v_summe at the beginning of the function too, I don't understand how Modelsim can give you an answer other than XXXXX when you do arithmetics on uninitialized vectors. I also assume that you are using the non standard std_logic_(un)signed library. You should consider using numeric_std instead and the signed/unsigned types, this is the recommended way.
