Avalon to AXI implementation
Hi Richard,
yes, I recognised this, too, that here are some signals missing (EMIF core & Avalon CCB).
- Is there an option in the Avalon CCB & EMIF core to enable those?
- How can I create a custom component for an standard IP? Would this be a custom component instantiating the EMIF core?
I tried to edit the interface of those IP cores in the component section in QSYS but I cannot add further signals.
I already read through the EMIF user guide (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-emi.pdf) but I could not found any setting to enable/disable pending write transactions.
Currently I am using the autogenerated interconnect from QSYS to resolve 256b AXI (BL = 16) to 512b Avalon (BL = 8).
Here I did not see any errors in the QSYS only the hint that an Avalon adapter will be inserted between AXI <-> Avalon.
Are there any special settings of the mm_interconnect I have to configure to do the bus conversion?
From the documentation of the Platform Designer I assumed this will be done by mm_interconnect automatically.
Do you have any reference design (QSYS) where a AXI <-> Avalon connection with bitwidth conversion + burst conversion is done?
That would be helpful to understand the settings on both sides to align them for the best throughput performance.
Kind regards,
Michael
Hi @MichaelB
Unfortunately I do not see a way to enable those.
You may launch the Component Editor by double-clicking New Component at the top of the IP Catalog or by selecting New Component from the File menu.
You may checkout the training video below. Chapter 9. Creating custom component.
https://www.intel.com/content/www/us/en/programmable/support/training/course/oqsys3000.html
You do not need to configure anything. As you mentioned, this will be done by mm_interconnect automatically.
https://www.youtube.com/watch?v=LdD2B1x-5vo
This is the closest design example that I found with AXI and Avalon connection.
Richard Tan
- RichardT_altera5 years ago
Hi @MichaelB
May I know does my latest reply helps?
Do you need further help regarding to this case?
Richard Tan
