11 years agoAvalon MM: writedata and write
Hi, a beginner's question, when passing data from HPS to the FPGA I use the AVALON MM interface. Now I'm a bit in doubt, if it is better to check "write" and then fetch "writedata" into a reg (verilo...
11 years agoHi, thank you for answering so fast. Well, in the meanwhile I figured out, it was a timing issue: I gave an explicit "start" signal and checked then for "write", but "write" arrived before "start" due to the setup.
Still, my curiosity is rather to understand, why I should check for "write" as a signal at AVALON MM? What may happen if I don't check this?
