11 years agoAvalon MM: writedata and write
Hi, a beginner's question, when passing data from HPS to the FPGA I use the AVALON MM interface. Now I'm a bit in doubt, if it is better to check "write" and then fetch "writedata" into a reg (verilo...
11 years agoIf you want your logic to retain the value that has been written for a period of time greater than the brief time when 'write' is being asserted, then yes you would want to store it in a register.
If your logic doesn't care (for example, because 'algo_in' feeds to 'algo_out' and that result gets latched), then using a wire as you have done is fine.
