11 years agoAvalon MM Slave waitrequest signal modus-operandi
Greetings, everyone. I'm trying to integrate a custom peripheral in the HPS system using an Avalon MM Slave and the Lightweight H2F bridge, but I'm having s little trouble with the sync of the ...
11 years agoThks again, BadOmen. I am a little busy with other affairs, as soon as I'm finished I'll test your suggestions. It is the first time that I'm dealing with Avalon, the waitrequest approach seemed to be the way to achieve the kind of synchronization that I need, but it seems that your suggestion to pipeline the operations is even better. In fact, it should fit the requirements of the final module. May I ask you if you could show me some reference of how to do the pipelining you had suggest? The final goal should have variable latency, then it would be good for me to learn how to fine tune the transaction.
Best regards and happy holidays.
