11 years agoAvalon MM Master Template - Writing makes Nios2 crash
Hi, I've implemented a Avalon Master MM master template to manually write a SDRAM (which is shared with my Nios processor). The source code is the following:
-- From component
writer_contr...
11 years agoMake sure that your Avalon MM master does not perform any accesses while the waitrequest signal is asserted. This is one of the most critical things with avalon masters
/Boris
