11 years agoAvalon MM Master Template - Writing makes Nios2 crash
Hi, I've implemented a Avalon Master MM master template to manually write a SDRAM (which is shared with my Nios processor). The source code is the following:
-- From component
writer_contr...
11 years agoThanks for your reply.
Is there any way I can lock the Nios while I'm writing the SDRAM ? I tried to do it using shared IOs but I haven't been able to make it work since the Nios had to poll a signal (a thus access the SDRAM)...
