18 years ago
Avalon-MM master? in SOPC for a FLASH mem
Dear ALL
I have opened the SOPC builder , added the FLash p30 along with the tristate_bridge.
I am getting an error:
Error: tristate_bridge: "tristate_bridge.avalon_slave" must be connected to an Avalon-MM master
What is the Avalon-MM master?
Could it be the VHDL code i wrote that add data or reads data at a certain memory loction
Best Regards
Dharmesh Joshi
    You probably have the SOPC system generated. How about your Avalon master? The error message indicates that you don't have Dj_Flaash_inst source code written.
    What source do you plan to write your data from and where do you plan to read the data to? If your current read/write module is readily available, you can just convery the ports to match the Avalon-MM master spec.
    Thanks Guys I got that working, and for some reason its no longer working. But i have got a VHDL generated. I just used the templet to create my master.
    Now when import the file into Quartus i get the following message
    Error: Node instance "the_Dj_Flaash_inst" instantiates undefined entity "Dj_Flaash_inst"
    the_Dj_Flaash_inst : Dj_Flaash_inst
    port map(
    avm_m0_address => Dj_Flaash_inst_m0_address,
    avm_m0_read_n => Dj_Flaash_inst_m0_read_n,
    avm_m0_write_n => Dj_Flaash_inst_m0_write_n,
    avm_m0_writedata => Dj_Flaash_inst_m0_writedata,
    avm_m0_readdata => Dj_Flaash_inst_m0_readdata,
    avm_m0_waitrequest => Dj_Flaash_inst_m0_waitrequest,
    clk => clk,
    reset_n => Dj_Flaash_inst_m0_reset_n
    Can you shines som light.
    Once this is working have i done it correctly to be able to read and write to the memory.
    Djoshi
    You need to alter the base addresses of the Avalon Slaves in the SOPC Builder window to clear the messages. You can try "Auto-Assign Base Addresses" from the "System" menu. But if that doesn't work you can do it manually.
    Dear Avatar
    I have manged to get the SOPC working. Using the compnent wizrd i have made he Avlone master, i then edited the pins, so there are appropiate. I am now getting the following eerros
    Info: cfi_flash: Flash memory capacity: 16.0 MBytes (16777216 bytes).
    Error: hpdj_inst.m0: "cfi_flash.s1" cannot be at 0xffff (0x0 or 0x1000000 would be OK)
    Error: hpdj_inst.m0: "cfi_flash.s1" (0xffff..0x100fffe) outside range (0x0..0xffffff)
    Error: tristate_bridge.avalon_slave: Must be at address 0x0
    I have tried to correct it. BUt not changes to errors
    Am i correct in beliving this will generate a VHDL files that will let me write and read to the Flash.
    Regards Dharmesh Joshi
    Where can i get this info from
    So if i was create a simple VHDL that write to the salve bridge shouldent that work
    You really need to step back and read about the Avalon switch fabric.
    One such Master could be the Nios II processor.
    Another could be any item in the components list that can be a Maser to the Avalon Switch
    fabric.
    Perhaps a DMA master to some POI ports?
