18 years agoAvalon-MM master? in SOPC for a FLASH mem
Dear ALL I have opened the SOPC builder , added the FLash p30 along with the tristate_bridge. I am getting an error: Error: tristate_bridge: "tristate_bridge.avalon_slave" must be conne...
18 years agoYou probably have the SOPC system generated. How about your Avalon master? The error message indicates that you don't have Dj_Flaash_inst source code written.
What source do you plan to write your data from and where do you plan to read the data to? If your current read/write module is readily available, you can just convery the ports to match the Avalon-MM master spec.
