17 years ago
avalon interface
hi,
I designed a component and i need to interface it with Avalon Bus.
one part of signal designed to comunicate with avalon interface and others to communicate with others logic.
my question is:
is it possible to declare all signals in top level file of my new component.
in SOPC builder, I chosen signals that i needed to communicate with avalon Bus and I assign the rest of signals to EXPORT.??
can someone help me ?
thks for all
    if you name your signals according to an altera doc like
    gls_clk for the clock
    gls_reset for reset
    avs_slave_chipselect
    avs_slave_address
    avs_slave_read
    avs_slave_readdata
    avs_slave_export_nCS
    then sopc builder automatically recognize the signals correctly and assigns them to the interface, so no need to do that by hand.
    there is an altera doc available that explains the syntax
    Correct.
    Declare all of your ports in the top level then in SOPC Builder select which ports are avalon signals and which "export" to the outside world.
