11 years agoAvalon bridge question
Hi. I'm trying to build a system with address decoding in Qsys. What I want (see the picture) http://www.alteraforum.com/forum/attachment.php?attachmentid=9902&stc=1 - I want address BRAMs usin...
11 years ago --- Quote Start --- If you are asking if there is a 4-port Avalon-MM bridge, the answer is no. The best you can get is probably the MPFE Verilog. Or, you can do something like instantiate 4 bridges and connect them to the same slaves (onchip memories). You can then connect 4 masters to the bridges and then access to the memories will be arbitrated independently. --- Quote End --- Hi ted, Is the arbitration automatic? How to avoid conflict?
