17 years agoAuto-Negotiation FAILED with TSEMAC and PHY Marvell 88E1111
I'm trying to check single socket example in a Cyclone III EP3c40. I've configured in SOPC in both case: as 10/100/1000Mbps Ethernet Only as 1000Mbps Small MAC result was always the sa...
17 years agothere are some things you can check:
-the MDIO communication with the PHY is working correctly? I suppose yes, otherwise it wouldnt recognize your Marvell PHY. -the clock signals you use with both mac and phy are with the correct freq? -your host PC NIC is able to auto-negotiate? maybe it worked with the 10/100, because these ones normally dont use autonegotiation. - I wouldnt use the 1000 Small MAC config. in the TSE, because this way your are telling him only to connect if there is a Gigabit available on the other side, and it is probable that your PC dont have it
