12 years agoaudio problem
how can i connect audio codec wm8731 to the filter fourier transform !!! how can i send the audio from the microphone to the filter fft fourier transform then to the headphone!!! the first part...
12 years agoAs I can see from your code, in the "audio.vhd" file, you are storing the data in "AUD_DACDAT" to send it out to the D/A Converter for headphones. Before doing that, you can invoke your filter. It should be fairly simple. I have modified the "audio.vhd". You can see the changes I have made under the tags "CHANGED". I did not compile it but it should be able to do what you ask.
Regards, Berk
