11 years agoaudio input and sampling via altera DE1 kit using SD card
here are the question i facing when using SD card as input source in altera DE 1 kit 1. How do i able to read a .wav audio file in SD card using FPGA kit via Verilog HDL coding? 2. How do i able to sample the audio's sampling frequency? 3. Are I able to mix 2 audio files together via using FPGA kit or i need to mix it before i insert the audio file into the FPGA kit 4. How to implement megawizard into the coding??No RepliesBe the first to reply
