ASx4 Interface debug in MSEL=111 (JTAG mode)
Hi Frank,
thank you. Unfortunately looks like this. I also did not find any explicit mention. Nevertheless I would appreciate from Altera when there would be a warning message in the console log (at least) that I am trying to do something not supported. Since having SDM I found no way of testing the memory connection over JTAG when something is wrong. In the BSDL file there are no IO buffers defined for the SDM_IOxx either.
What was by the way a strange thing in the AN995 that it was mentioning that I have the ASx4 debugging available when the FPGA programmed with an active serial x4 enabled image. So the question is that setting also part of the SRAM image I am programming? does the FPGA know that the .sof image I program supposed to be read normally from NOR over ASx4?
Or it is more related to the MSEL inputs only and nothing else.
Peter
- JohnT_Altera5 months ago
You will be able to access the QSPI Flash when you are using MSEL set to JTAG mode. https://docs.altera.com/r/docs/847422/25.3.1/device-configuration-user-guide-agilextm-3-fpgas-and-socs/debugging-guidelines-for-the-as-configuration-scheme
May I know which board are you using and if you are using custom board, can you share with me your board schematic so that I can understand what is actually causing the issue?
If you are able to provide some screenshot of the SFDP then it will be also provide some basic information. - JohnT_Altera4 months ago
Hi Peter,
May i know if you have the updated information?
