11 years agoAS Configuration Problem with EP3C25E144
Hello ! i have designed circuit in EP3C25E144 TQFP FPGA. I am using both configuration scheme i.e JTAG and AS for EPCS64. Using the same connection schemes as mentioned in Altera Cyclon III c...
11 years agoIt is recommended to pull the nCE pin of the FPGA to ground with 10k resister at AS mode, but connect to ground directly at some other mode. Please try this!
