11 years agoAS Configuration Problem with EP3C25E144
Hello ! i have designed circuit in EP3C25E144 TQFP FPGA. I am using both configuration scheme i.e JTAG and AS for EPCS64. Using the same connection schemes as mentioned in Altera Cyclon III c...
11 years agodon't click on the 'Open Conversion Setup Data...' button. Follow the instructions I sent you.
1) Set the 'Programming file type:' to 'JTAG Indirect Configuration (.jic)' 2) Select your 'Configuration device:' - EPCS4/16/64 3) Chose an output file '*.jic' (or leave it as output_file.jic) 4) Under Input file to convert, click on Flash Loader and then the 'Add Device...' button. Chose your FPGA (Cyclone III, EP3C25). Click OK. 5) Click on 'SOF Data' and then the 'Add File...' button. Chose your .sof. Click OK. 6) Click 'Generate'. Load the resulting .jic into the programmer and you're off. Cheers, Alex
