11 years agoAS Configuration Problem with EP3C25E144
Hello ! i have designed circuit in EP3C25E144 TQFP FPGA. I am using both configuration scheme i.e JTAG and AS for EPCS64. Using the same connection schemes as mentioned in Altera Cyclon III c...
11 years agoTry programming the EPCS via JTAG using a .jic file.
Follow the instructions in app note 370 (http://www.altera.co.uk/literature/an/an370.pdf), see page 6 "generating .jic and .jam programming files in the quartus ii software". Once generated, connect to your target via your JTAG connector. Load the .jic file into the QUartus programmer and see if it'll program the EPCS that way. Cheers, Alex
