11 years agoAS Configuration Problem with EP3C25E144
Hello ! i have designed circuit in EP3C25E144 TQFP FPGA. I am using both configuration scheme i.e JTAG and AS for EPCS64. Using the same connection schemes as mentioned in Altera Cyclon III c...
11 years agohave you checked the EPCS type used on Hardware is same as assigned in QII to ensure the programming file matches the HW? have you chosen the option to generate a compressed programming file - maybe it's worth to start with a non - compressed one
(there was a QII version generating fautly *.pof when compressed option is active, but I think this was round about QII ver.11.x to 12.x but not 13.1 sp1)
