JAlin
7 years agoAS configuration not working with Arria10
I have a new board with Arria10, and configuration is not working from a SPI flash in Active Serial mode. I have programmed the flash using USB blaster rev B and the flash verification is ok. All the...
JohnT_Altera
7 years agoHi,
You will need to make sure that the dummy clock is matching the device specification or select the similar flash to generate the correct content.
