JAlin
7 years agoAS configuration not working with Arria10
I have a new board with Arria10, and configuration is not working from a SPI flash in Active Serial mode. I have programmed the flash using USB blaster rev B and the flash verification is ok. All the...
JAlin
7 years agoWe had Macronix on the beard, because Arrow's FAE told us that 18.1 will support MAcronix and Cypress. We already tried some Micron samples that we had lying around and they worked.
When will there be support for other vendors then? What are the exact requirements for the configuration to work? We have a requirement that there should be second sources for flash memories.
