JAlin
7 years agoAS configuration not working with Arria10
I have a new board with Arria10, and configuration is not working from a SPI flash in Active Serial mode. I have programmed the flash using USB blaster rev B and the flash verification is ok. All the...
JohnT_Altera
7 years agoHi,
May I know what is the SPI flash use? When you convert the programming file, do you select the correct flash? Currently we support EPCQ-L and MT25Q flash only. It does not check for ID code but I suspect that either the content is corrupted where the FPGA keep on restart configuration.
