18 years agoAS config problem
Hi, When I used Byetblaster(I also tried to use Usb blaster) download the config file to the EPCS64,Quartus2 report that : Can't recognize silicon ID for device. Does anyone know what a EPCS ...
18 years agoHi,
Thanks for your help. Iam sorry I had make a mistake.The nCSO pin is a high level and the the nCE is low. I checked the schematics,Iam sure the schmatic is the same as the Datasheet ,and I measured the voltage on the MSEL pins, they are set the right position.Is there any other point that I can't think?
