14 years agoAS and JTAG access to cyclone II device
Hello, I did a design that has both JTAG access and AS access to a single cyclone II device, and am looking to see if I did it correctly. For the AS circuit, I just used the suggested circuit ...
14 years ago- open File > Convert Programming Files
- select .jic (JTAG indirect) as the output type
- select appropriate EPCS device
- click SOF data, then Add File to add your .sof
- click properties to optionally enable compression
- click Flash Loader then Add Device to select your target device
- click Generate
- open Tools > QII Programmer
- click Auto Detect
- double click in File column of your FPGA device row
- select .jic file
- click the Program/Configure check box in the new EPCS device listed
- click Start
