11 years agoArriav V FPGA doesn't work.
Hello, everyone : I have a problem in my design. Arriav V FPGA can download successfully, but it does not work. I use combinational logic to assign 55AA in my VHDL code. After I download it to FPG...
11 years agoAre you sure the device is configuring? I assume you're configuring via JTAG and the Quartus II programmer is confirming that configuration was successful?
If you can confirm that the device is configuring then check the DEV_OE pin. That pin can be used to tri-state all I/O on the device.
