AlehTS
5 years agoArria10 transceivers and CSI
Hello.
I have a task to receive data from CSI sensor.
This sensor has CSI bus with 1 clock line and 4 data lines. Data are transferred on both edges of the clock. The clock rate is about 1.5GHz....
- 5 years ago
HI,
Pls see my reply below.
- Does this mean, that it is not possible to receive data without embedded clock ?
- Correct. Transceiver architecture is meant to receive data transfer with embedded clock
- And generally, is it possible to receive data from CSI source using transceivers ?
- From Intel FPGA perspective, we don't support MIPI IP solution
- So, unfortunately this is something beyond Intel support plan and you will need to explore by yourself
- One thing that raise my concern is you mentioned long continuous of 1 or 0 data pattern transfer. This is bad for transceiver receiver architecture and it will caused CDR to loose lock. For typical high speed protocol application, it will trigger to send "IDLE" data pattern to keep the CDR locked if there is no active data transfer on-going.
dlim
Deshi_Intel
5 years agoHI,
dlim
- AlehTS5 years ago
Hi, dlim!
1. I do not plan to use ready-made IP for MIPI. I'll create it by myself.
The only thing I need from transcievers is to deserialize data.
Normally, long 0 and 1 are not a problem for CSI, because the clock is transmitted over separate line.
So, if transceiver circuitry can not be used for my purpouse, can I use simple altlvds_rx deserializer, which is connected to transccieiver pins? Transceiver pins can accept much higher frequencies, than ordinary pins.
2. Do I understand correctly, that the same situation is with transmitter? I mean, that tramsmitted signal always has embedded clock.
Thank you.
Oleg.
