TSuzu6's avatar
TSuzu6
6 years ago
Arria10 transceiver PHY rx_control[] issue
Hi!
In our Arria10 device, transceiver phy is configured as below,
-Transceiver Configuration rules:Basic(Enhanced PCS)
-PMA configuration rules:basic
-Number of data channels:6
-Data rate:6144Mbps
-TX channel bonding mode:PMA and PCS bonding
-"Enable tx_pma_div_clkout port" is checked, division factor=33
We checked "Enable rx_seraillpbken port" and set to 1'b1 for serial loop back mode.
[result]
6 channels tx_control[1:0] are set to 2'b01.
But rx_control[1:0] of some channels are sometime different from 2'b01.
We attached the signal tap capture "WS000028.JPG"
WS0000028.JPG:
tx_control and rx_control signals are captured.
signal name description
tx_control[11:10]: tx_control[1:0] for channel 5
tx_control[ 9: 8]: tx_control[1:0] for channel 4
tx_control[ 7: 6]: tx_control[1:0] for channel 3
tx_control[ 5: 4]: tx_control[1:0] for channel 2
tx_control[ 3: 2]: tx_control[1:0] for channel 1
tx_control[ 1: 0]: tx_control[1:0] for channel 0
rx_control[11:10]: rx_control[1:0] for channel 5
rx_control[ 9: 8]: rx_control[1:0] for channel 4
rx_control[ 7: 6]: rx_control[1:0] for channel 3
rx_control[ 5: 4]: rx_control[1:0] for channel 2
rx_control[ 3: 2]: rx_control[1:0] for channel 1
rx_control[ 1: 0]: rx_control[1:0] for channel 0
Why are tx_control and rx_control not same ?
We suspect transceiver PHY reference clock jitter.
Cloud you tell reconfirm point ?
BR,
taira
  • Deshi_Intel's avatar
    Deshi_Intel
    Hi Taira,
    No problem. I will keep the case open and waiting for your update in May.
    FYI... Malaysia is impacted by COVID-19 as well. I have been working from home and fully understand your pain point from not able to work from office.
    dlim
  • TSuzu6's avatar
    TSuzu6
    ​Hi, dlim
    Thank you for your Information.
    I want to confirm your check points, But My office is closed for COVID-19.
    Maybe, until 6-May-2020.
    So I will reply, when I can confirm .
    BR,
    Taira
    Deshi_Intel
    Hi Taira,
    From your signal_tap result, rx_control [5:0] looks fine while rx_control[11:6] result looks bad.
    • Is this failure trend consistent meaning failure always occurs on rx_control[11:6] ?
    • I presume the mapping is transceiver channel [2:0] is good while transceiver channel [5:3] is bad ?
    Yes, transceiver clocking performance could be a concern here.
    • Does resetting NativePHY IP helps to resolve the issue ?
    • I presume you are using fPLL ? Is the fPLL sitted closer to channel [5:3] or [2:0] ? Does changing to other fPLL helps to resolve the issue here ?
    • Also are you using dedicated refclk pin to clock the fPLL ? Else pls take note of below KDB known issue
    • https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2017/fb470823.html
    • You can try reduce the data rate from 6G to lower data rate to see if it helps
    • You can also compared the CDR lock status signal (rx_is_lockedtodata) between good channel and bad channel to see id CDR loose lock is causing the issue here
    • Finally pls measure the on board transceiver PLL refclk pin and CDR refclk pin clocking signal to ensure the clock source is clean and stable
    dlim
