jozephka99
Contributor
4 years agoArria10 SoC Dev Kit Beginner Help
I used MAX10 series (DE10-Lite) before then I switch it to Arria10 SoC Dev Kit. I read the documentation about the board -no need to say it is awfull-. When I want to start with the beginner th...
EricMunYew_C_Intel
4 years agoIn your Golden top, you need to enable the UART in Platform designer and regenerate the qsys.
You may refer to below.
jozephka99
Contributor
4 years agoI try both route to HPS and FPGA but what should I do after the routing. Platform designer export the uart pins but when I try the use that pins I can just receive something and couldn't transmit anything. When I connect J10 usb uart to the minicom, it automatically send hps debug despite I route J10 to the fpga. I think I must do something in the hps side either but I don't know exactly. So what's the problem and what can I do?
