Arria10 SoC Dev Kit Beginner Help
Thanks for advises. Yes I'm referring that kit. I found a project named "golden_top" in the examples that shows pin connections of board. I saw most of my before pin assignments are true. I succeed the leds working. (they are active low btw). But I still couldn't find FPGA RS232 UART pins. In golden_top there is no assignment for that UART. May be the FPGA UART pins have multiple connections and there for the other connections write in the golden.
- EricMunYew_C_Intel4 years ago
In your Golden top, you need to enable the UART in Platform designer and regenerate the qsys.
You may refer to below.- jozephka994 years ago
Contributor
I try both route to HPS and FPGA but what should I do after the routing. Platform designer export the uart pins but when I try the use that pins I can just receive something and couldn't transmit anything. When I connect J10 usb uart to the minicom, it automatically send hps debug despite I route J10 to the fpga. I think I must do something in the hps side either but I don't know exactly. So what's the problem and what can I do?
