Arria10 FPGA config directly from TFTP
Hi TG_GER,
If I understood correctly, I think the peripherals.rbf should consider the total size of the ram which can be used in your system and it should consider the 4gb external ram in your design as well. I think the HPS EMIF interface will need to consider the 4gb external ram as well. Below is the reference regarding the early IO release.
Early I/O Release Use Cases
There are a few different reasons why you might choose to enable the Early I/O
Release feature of the Intel Arria 10 SoC FPGA device. The typical reason is to speed
up system boot and configuration time. By gaining early access to a large pool of
system RAM connected the HPS EMIF interface, the boot software can more efficiently
load the bulk of the FPGA configuration image from mass storage. Restricting boot
code to on-chip RAM typically impedes bulk transfers because of the limited code and
buffer space.
Aik Eu
