cepni's avatar
cepni
4 years ago
arria10 ddr3 vref mistake
hi, ddr3 interface connected 3A and 3B banks, Vref3a and vreg3b pins connected 0V(ground). Can I use internal Vref voltage reference ?
  • AdzimZM_Altera's avatar
    4 years ago
    Thank you for using Intel Community.
    I am Adzim, application engineer will help you on this topic.
    The ddr3 interface required the Vref connection for the data pins only.
    You should refer to Quartus compilation report on which IO bank that required the Vref connection.
    "Can I use internal Vref voltage reference ?"
    • Yes you should be able to use that.
    Adzim
