lcoon1981
4 years agoArria V GZ Transceiver Native PHY reference design using the 10G PCS
Is there any reference design available for AV GZ using the Transceiver Native PHY with 10G PCS to achieve 12.5 Gbps performance? I will be using Arria V 5AGZME7H2F35I3 for the project.
Thank...
- 4 years ago
Sharing the design example link
https://community.intel.com/t5/FPGA-Wiki/Arria-V-Transceiver-PHY-Basic-Design-Examples/ta-p/735223
Thank you
Kshitij Goel
Kshitij_Intel
4 years agoHi,
You must be able to generate the example design using IP Parameter Editor for the required configuration.
FYR Refer to V-Series Transceiver PHY IP Core User Guide(attached).
Thank you
Kshitij Goel
