9 years agoarria V FPP programing doesn't work
hi, I have a problem trying to program my arria V using a CPLD. I am using a compressed rbf file and the MSEL pins are set as needed "10110" for compressed file with FPP x8 bit programming schem...
9 years agoWithout going into the hardware, did you set the type of programming you were going to use in the Device & Pin Options settings in Quartus before generating the programming files?
