RobertOlson's avatar
RobertOlson
4 years ago
Arria V FA support request for Honeywell 5AGXFB5K4F40I3G- 1pc
Form #: 2138268
BEI Part #: HWL52000859-50
Mfg. Part #: 5AGXFB5K4F40I3G
Purchased from Arrow Electronics
Original PO #: WPM286596
Quantity to return: 1
Date code: 2131
Reason for return: Physical damage found prior to use- Masking damage
  • RobertOlson's avatar
    RobertOlson
    Hi Wani,
    Same situation with this part, it is a fresh, unused unit. It hasn’t gone through any processing or testing.
    The physical damage was found prior to use- Masking damage
    Thank you,
    -Rob Olson
    507-535-4083
  • Zawani_M_Intel's avatar
    Zawani_M_Intel
    Hi RobertOlson,
    Good day!
    Thank you for using Intel FPGA Community Forum.
    The case will be supported through private email.
    Thanks!
    Wani
