12 years agoArria V (5AGXBB3D4F35C4): CONF_DONE pin failed to go high in device 1
Hi, I am using Arria V FPGA. I am getting the "CONF_DONE pin failed to go high in device 1" error. I have 2 similar boards, one is working fine. If i programmed the same sof file to 2nd boa...
12 years agoI have checked the both boards all the parameters like resistors, voltage & Diode continuities.
After the fab i verified the programming, it's fine. After some days suddenly it gets stopped. Regards, Venkatesh.
