12 years agoArria V (5AGXBB3D4F35C4): CONF_DONE pin failed to go high in device 1
Hi, I am using Arria V FPGA. I am getting the "CONF_DONE pin failed to go high in device 1" error. I have 2 similar boards, one is working fine. If i programmed the same sof file to 2nd boa...
12 years agoIf one board is working fine and the other isn't it sounds like you have a build fault. Are you happy the pull-up resistor on the CONF_DONE pin is fitted correctly and the correct value? Are you happy all the FPGA's power rails are good on the non-working board?
Regards, Alex
