16 years agoArria II with single DDR3 SODIMM
Hello, I am trying to use an Arria II with a single DDR3 SODIMM and was wondering if I can avoid parallel termination and use a simpler termination scheme. I can place the SODIMM as close to th...
16 years agoJake, thank you for the critical feedback - you saved me a lot of time. Too bad the Arria II doc is not clear about this. I was trying to save board space by using a DIMM, but I will probably follow your suggestion and put the chips on the main board. Too bad read/write leveling is only available in the Stratix family...
FvM, I thought I had just download AN520 in the last few days, but you are right; it's gone now. I hope it will be replaced with a more up to date version. Thanks for all the help!
