13 years agoArria II Power Supplies - Switcher or Linear?
Upon reading through the Arria II Device Family Pin Connection Guideline document (PCG-01007-1.5), we noticed that only switcher power supplies are used in the power tree examples for the VCC (0.9V) ...
13 years ago --- Quote Start --- Yes, there are analog circuits on the PCB board as well, and we are really concerned about noise in this application because of the analog circuits associated with the application. --- Quote End --- Ok. Then analyze the FPGA power requirements and see if they can be met by linear supplies. If the FPGA needs to use a switcher, then you will need to pay attention to layout. If your analog section can use differential signalling, then that will improve the common-mode rejection of any switching signals. Micrel have a range of switcher noise suppression linear regulators; basically active filters acting as low-dropout regulators. You might be able to use those to cut down the noise from the digital section of the board. Cheers, Dave
