17 years ago
Arria II GX: Unconstrained clock in tranceiver reconfiguration block
by fitting my design I get warnings like this:
Warning: Node: ...alt2gxb_reconfig_rhm_component|alt_cal:calibration|alt_cal_edge_detect:pd0_det|pd_negedge was determined to be a clock but was found without an associated clock assignment.
One reconfiguration block is connected to four instances of a tranceiver channel with different starting_channel_number. There is one pll in the design. The reference clock and the reconfiguration clock are generated by this pll.
I'm using Quartus II 9.0 SP2.
This is the content of the TimeQuest sdc file:
derive_pll_clocks -create_base_clocks
derive_clock_uncertainty
set_false_path -from [get_ports {ResetN}]
Do I have to add something to the sdc file?
Thank You!
    I still have this question for a Stratix IV GX and GT device as I get the same message even using Quartus v9.1 SP1. I cannot figure out what I need to do if anything.
    I had the same question for the Stratix IV device and Altera apps confirmed that this issue is expected to be fixed in Quartus 9.1 production release (Nov 2009).
    These warning messages are shown in 9.0 sp2, but the function is not affected. The reconfiguration function works well in hardware.
