11 years agoArria II - GX Jitter performance
Hi All, I am using arria II GX : EP2AGX45DF29I3 fpga in my porject. I referred the datasheet of arria II GX and saw the transceiver jitter performances of the GX series fpga's for different pro...
11 years agoI'm not convinced GX parts will run at 6.375Gbps.
The maximum refclk for the GX parts is 622.08MHz. The serializer then gives a maximum serial data rate of 6.22Gbps. The GZ parts support a 637.5MHz refclk (and higher) giving the 6.375Gbps you're after. So, I think the devil is in the detail and, perhaps, explains why there are no references to anything over 6Gbps in the datasheet for GX parts. Cheers, Alex
