Arria 10 will not load from Micron MT25QU256 PROM
I am using an MT25QU256 PROM to program an Arria 10 10AX027E4 device. The MSEL setting is active serial standard power on (011). The programming voltage is 1.8V. It appears that the access to the PROM starts normally then terminates early. I have attached scope shots of the transactions between the FPGA and the PROM. One thing I see is that the FPGA de-asserts the select and stops the clock just before reading the last bit of a byte.
I have followed all the recommendations for using the MT25Q devices. I believe that the file is compressed.
Can somebody explain what I'm seeing and how to fix it?
- JCass5
Good morning Nooraini,
This morning I started the programming process from scratch. I verified that the MT25QU was selected as the target device in Quartus and that I was using Active Serial. In the file conversion program I set all the parameters from scratch instead of loading my .cof file. I generated the .jic and programmed the target board. When I power cycled the board the FGPA loaded correctly.
I then went back into the file conversion program and loaded my .cof file. Here my .cof file was selecting a .sof from an old version of the design that was Cyclone V based. Once I changed this to the A10 .sof file it also generated a .jic file that loaded on power-up..
I think Intel needs to put a check in the file conversion utility that makes sure the .sof file selected matches the target device.
Jim Cassey
- Nooraini_Y_Intel
Hi Jim,
Apologize for the delay in response. It's good to know you are able to resolve the issue and move forward with your design and we will take note on your feedback. At least you were able to identify the root cause due to the incorrect .sof file being selected in the .cof file and resolve the issue. This information will be benefit for other users if they encounter similar failure.
Nooraini
