Suresh430's avatar
Suresh430
1 month ago
Arria 10 SoC Dev Kit – Linux from SD Card Stops Booting After Erasing EPCQL1024
Hi Team, I am working with the Intel/Altera Arria 10 SoC FPGA Development Kit (10AS066).
Please find the issue description in attached file and image.
Thank you
Suresh
  • KianHinT_altera's avatar
    KianHinT_altera
    Hi Suresh,
    Sorry for the delay in getting back to you. As for your question , I presumed you're using DK-SOC-10AS066S-E Arria 10 SX SoC Development Kit
    You can refer to this page on how to setup and boot Linux via SDcard
    https://altera-fpga.github.io/rel-25.1.1/embedded-designs/arria-10/sx/soc/gsrd/ug-gsrd-a10sx-soc/
    and this if you want to change some settings you can manually rebuild the software
    https://altera-fpga.github.io/rel-25.1.1/embedded-designs/arria-10/sx/soc/boot-examples/ug-linux-boot-a10-soc/
    I suspect your board switches are not set correctly, but do refer to the guide. Before flashing anything try resetting those switches back to default.
    Kian
      KianHinT_altera
      Hi Suresh,
      May I know whether you have resolved this issue on your end?
      regards
      Kian
      • Suresh430's avatar
        Suresh430
        Hi Kian,
                    Thanks for u r update. I wanted to know after loading the ref .sof file, how hps will boot with linux image from sd card. Where is the configuration stored th tell the HPS. This things are not clear to me, please clarify for Arria 10 SoC Development Kit.
        Thanks in Advance
        Suresh
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
