Ezmartin
4 years agoArria 10 net lengths
I do not see the 10AS048EF29 in the net lenghts download from the following intel link:
https://www.intel.com/content/www/us/en/docs/programmable/683073/current/net-length-reports.html
Does one e...
Ezmartin
4 years agoHi,
Thanks for your response. Although the device that I am looking for 10AS048EF29 does not exist in the list of netlength worksheets from that link. Below is a snapshot of the 10AS devices within that link.
Please advise if the 10AX048EF29 and the 10AS048EF29 use the same pin package netlengths.
Thank you
AminT_Intel
4 years agoHello,
Thank you for pointing that out. I will need to check with my team to see if we help you with this issue.
Thank you,
- Ezmartin4 years ago
Just wanted to follow up to see if you or your team has found a solution to this issue.
Please email me your response or the pin package delay for the device I'm in need of.
Thank you,
DM
- AminT_Intel4 years ago
Attached is the file you've requested.
Thank you
Thank you for your assistance.
