Ezmartin
4 years agoArria 10 net lengths
I do not see the 10AS048EF29 in the net lenghts download from the following intel link:
https://www.intel.com/content/www/us/en/docs/programmable/683073/current/net-length-reports.html
Does one e...
AminT_Intel
4 years agoHi,
That will be under Arria 10 from the link you have shared.
Thank you.
Ezmartin
4 years agoHi,
Thanks for your response. Although the device that I am looking for 10AS048EF29 does not exist in the list of netlength worksheets from that link. Below is a snapshot of the 10AS devices within that link.
Please advise if the 10AX048EF29 and the 10AS048EF29 use the same pin package netlengths.
Thank you
- AminT_Intel4 years ago
Thank you for pointing that out. I will need to check with my team to see if we help you with this issue.
Thank you,
- Ezmartin4 years ago
Just wanted to follow up to see if you or your team has found a solution to this issue.
Please email me your response or the pin package delay for the device I'm in need of.
Thank you,
DM
Attached is the file you've requested.
Thank you
