jeelliso
2 years agoArria 10 NAND Flash Programming Hangup
I'm having issues programming a NAND Flash component through JTAG on multiple identical CCAs with an Arria 10 SoC. I'm using Quartus 20.1 system-console to execute a .tcl script that calls the "maste...
Farabi_Altera
2 years agoHello,
Can you try program the FPGA using Quartus programmer GUI?
from Quartus programmer GUI, what is the error message?
regards,
Farabi
jeelliso
2 years agoProgramming the .sof file directly to the FPGA using the Quartus GUI doesn't yield any errors. However, my problem is attempting to load to external NAND flash.
Could this be a bad block issue? Is there any additional visibility when "master_write_from_file" is called?
