FvM
2 years agoArria 10 IOPLL Dynamic Phase Shift using M-Counter
Hello, we use to perform clock fine tuning with Cyclone designs by applying continuous phase shift to M counter (PLL feedback clock divider). This way the frequency of all PLL output clocks is tune...
Farabi_Altera
2 years agoHi Frank,
Let me check with engineering on this. Did the phase shift you performed via M-counter is stable?
How long the PLL can get to Locked status after you performed the phase shift?
regards,
Farabi
- FvM2 years ago
Hi Farabi,
thanks for your interest.
PLL is staying locked after M-counter phase shift, Arria 10 IOPLL is behaving the same as Cyclone 10 LP which provides M-counter dynamic phase shift as documented feature.
Frank
